Using the Torch
WARNING
This device may have a flashlight that can be programmed to flash at various intervals. Consult your physician if you have epilepsy or are sensitive to bright or flashing lights.
Using the torch (flashlight) can reduce battery life. You can reduce the brightness to extend the life of the battery.
  1. Hold CTRL.
  2. Select Flashlight.
  3. If necessary, press ENTER to turn on the torch.
  4. Select an option:
    • To adjust the brightness or color of the torch, press UP or DOWN.
      TIP: From any screen, you can quickly press CTRL twice to turn on the torch. For the first three seconds, you can press UP or DOWN to adjust the brightness or color of the torch.
    • To program the torch to flash in a selected pattern, hold MENU, select Strobe, select a mode, and press ENTER.
    • To display your emergency contact information and program the torch to flash in a distress pattern, hold MENU, select Distress Pattern, and press ENTER.
      CAUTION
      Programming the torch to flash in a distress pattern will not contact your emergency contacts or emergency services on your behalf. Your emergency contact information will only appear if it has been configured in the Garmin Connect™ app.
GUID-B613EA0B-EFB7-451C-BA10-DB9EE5A990BF v4
September 2026
