Updating Applied Ballistics Data Using a Xero Rangefinder
Before you can update the Applied Ballistics® data, you must pair a compatible Xero® rangefinder (Pairing Your Wireless Sensors).
You can choose what Applied Ballistics data updates on your watch each time you range a target using your rangefinder.
- From the Applied Ballistics app, press ENTER.
- Select .
Select an option:
Select Target to update range, direction of fire, and inclination.
Select Target + Environment to update the target data, plus temperature, pressure, and humidity.
Select Target + Environment + Wind to update the target and environment data, plus wind speed 1, wind speed 2, and wind direction.
Parent Topic: Applied Ballistics Options
