Applied Ballistics Options
From the watch face, press ENTER, select Applied Ballistics, and press ENTER.
Quick Edit
Sets the range, direction of fire, and wind information (Quickly Editing Shooting Conditions).
Range Card
Displays data for various ranges based on user input parameters. You can change fields (Customizing the Range Card Fields), edit the range increment (Editing the Range Increment), and set the base range (Setting the Base Range).
Target Card
Sets the long-range shooting conditions for your current target, including range, elevation, and windage (Editing the Target). You can change the selected target and customize conditions for up to 26 targets (Changing the Target).
Environment
Sets the atmospheric conditions for your current environment. You can enter custom values, use the pressure and latitude values from the internal sensor in the device, or values from a connected wireless sensor (Environment).
Profile
Sets the bullet, gun, and scope properties for your current profile (Editing a Profile). You can change the selected profile (Selecting a Different Profile) and add additional profiles (Adding a Profile).
Change Fields
Customizes the data fields on the profile data screen (Customizing the Profile Data Screen).
Garmin LRF Settings
Updates Applied Ballistics® data, such as target and environment data, on your device each time you range a target using your paired Xero® rangefinder (Updating Applied Ballistics Data Using a Xero Rangefinder).
Settings
Sets the units of measure, decimal place precision, target labels, and fire control options for windage and elevation.
GUID-B613EA0B-EFB7-451C-BA10-DB9EE5A990BF v4
September 2026
