Navigating a Route
  1. On the remote control, select Menu button > Routes.
    A list of the ten closest routes is shown.
  2. Select a route.
  3. Select Navigate To.
  4. Select an option:
    • To navigate the route from the starting point used when the route was created, select Forward.
    • To navigate the route from the destination point used when the route was created, select Backward.
    • To navigate from your current location to the beginning of the route, then navigate the route, select From Start.
  5. Turn on the propeller (Turning the Propeller On and Off).
    The trolling motor drives along the route in the chosen direction (Navigating).
As you approach the end of the route, by default, the trolling motor switches to the anchor lock feature and holds position at the end of the route. You can change this behavior in the settings (Trolling Motor Settings).
GUID-B3BCDA2E-E3B8-4864-840E-DA1DB2C5C670 v7
November 2025
