Trolling Motor Settings
On the remote control, select Menu button > Settings > Trolling Motor.
Wi-Fi
Sets the wireless network preferences for the trolling motor (Wireless Network Settings).
Calibrate
Calibrates the trolling motor compass (Calibrating the Trolling Motor Compass) and sets the trolling motor bow offset (Setting the Bow Offset).
Units
Sets the units of measure.
Battery Management
Defines settings related to the trolling motor battery (Battery Management Settings).
Beeper
Disables or enables the autopilot notification beeps.
Prop Stow Side
Sets which side of the trolling motor the propeller rotates to when stowing the trolling motor. This is helpful when you store other items near the stowed propeller. This may also be necessary if you install a LiveScope™ transducer on the trolling motor.
Auto Power On
Turns on the trolling motor when you apply power to the system.
Heading Hold
Sets the behavior of the heading hold feature (Changing the Heading Hold Behavior).
Nav. Arrival
Sets the behavior of the trolling motor when you reach the end of a route. With the Anchor Lock setting, the trolling motor holds the position using the anchor lock feature when the boat reaches the end of the route. With the Manual setting, the propeller turns off when the boat reaches the end of the route.
CAUTION
When using Manual for the Nav. Arrival setting, you must be ready to take control of the boat.
Anchor Gain
Sets the level of autopilot response when in anchor lock mode (Adjusting the Autopilot Response).
Navigation Gain
Sets the level of autopilot response when in other autopilot modes (Adjusting the Autopilot Response).
Clear User Data
Deletes all saved waypoints, routes, tracks, and your active track.
NOTE: If you are connected to a chartplotter, selecting this clears user data from both the trolling motor and the connected chartplotter.
Restore Defaults
Resets the trolling motor settings to the factory default values.
NOTE: Restoring default settings does not clear user data on the trolling motor or on a connected chartplotter.
Clear Diagnostics
Deletes system-generated data that is stored on the trolling motor for troubleshooting purposes.
GUID-B3BCDA2E-E3B8-4864-840E-DA1DB2C5C670 v7
November 2025
