Shaping Your Route
Before you can shape your route, you must start a route (Starting a route).
You can manually shape your route to change its course. This allows you to direct the route to use a certain road or go through a certain area without adding a destination to the route.
  1. Select anywhere on the map.
  2. Select Shape Route.
    TIP: You can select Zoom in to zoom in on the map and select a more precise location.
    The device enters route-shaping mode and recalculates the route to travel through the selected location.
  3. Select Go!.
  4. If necessary, select an option:
    • To add more shaping points to the route, select additional locations on the map.
    • To remove a shaping point, select the shaping point and select Remove.
GUID-B3443908-7800-44A1-BE1E-0D780C075CBA v3
August 2023
