Your route on the map
As you travel, the device guides you to your destination using voice prompts and information on the map. Instructions for your next turn or exit, or other actions appear across the top of the map.
Active route on a navigation map with callouts
Call-out number one
Next action in the route. Indicates the next turn, exit, or other action and the lane in which you should travel, if available.
Call-out number two
Distance to the next action.
Call-out number three
Name of the street or exit associated with the next action.
Call-out number four
Route highlighted on the map.
Call-out number five
Next action in the route. Arrows on the map indicate the location of upcoming actions.
Call-out number six
Vehicle speed.
Call-out number seven
Name of the road on which you are travelling.
Call-out number eight
Estimated arrival time.
TIP: You can touch this field to change the information it shows.
Call-out number nine
Map tools. Provides tools to show you more information about your route and surroundings.
Call-out number ten
Map layers. Allows you to change the map orientation and add topographic and BirdsEye imagery to your map view.
GUID-B3443908-7800-44A1-BE1E-0D780C075CBA v3
August 2023
