Location Search Results
The location search results appear in a list, with the nearest location at the top. Each numbered location also appears on the map. You can scroll down to view more results.
Location search results list with callouts
Call-out number one
Select a location to view the option menu.
Call-out number two Information
Select to view detailed information about the location.
Call-out number three Alternative routes
Select to view alternative routes to the location.
Call-out number fourAdventurous routing
Select to start navigating using Garmin Adventurous Routing™.
Call-out number five Go!
Select to start navigating to the location using the recommended route.
GUID-B3443908-7800-44A1-BE1E-0D780C075CBA v3
August 2023
