Activating the Device
WARNING
Before you can use the inReach® features of your Tread® XL device, including messaging, SOS, and team tracking, you must activate the device.
  1. From your computer or smartphone, go to garmin.com/teamtracking to create an account and activate a service plan.
  2. Turn on the device.
  3. From the main menu on your device, select Team Tracking.
  4. Follow the on-screen instructions.
    NOTE: You must enter the device IMEI number and authorisation code to complete the online portion of the activation before you go outdoors.
  5. Go outdoors to an open area with a clear view of the sky and point the antenna on the device towards the sky for optimal performance.
  6. Wait while the device communicates with the Iridium® satellite network.
    NOTE: It may take up to 20 minutes to activate your device. The device must send and receive several messages, which takes longer than sending a single message during regular use. Your device should remain outdoors until activation finishes.
GUID-B3443908-7800-44A1-BE1E-0D780C075CBA v3
August 2023
