Editing Tracks
You can edit tracks that you have previously recorded.
From the main menu, select
> Apps > Tracks.
Select a track and select
The track appears on the map.
Select an option:
To add points to a track or extend the track, select Add and follow the on-screen instructions.
To delete a point from the track, select Delete and select a point on the track.
To move a point on the track, select Move and follow the on-screen instructions.
To reverse the track, select Reverse.
To join the current track with another track, select Join and select a track.
TIP: You can selectto undo the last action.
Parent Topic: Tracks
