Connecting Accessories
NOTICE
Do not use the device to control or power a winch. Failure to follow this notice could cause damage to your vehicle or your device.
NOTICE
Do not connect a power source to an accessory output terminal. Failure to follow this notice could cause damage to your vehicle or your device.
Accessory requirements:
  • Verify the amperage rating of each accessory before wiring it to the | device. The device supports accessories up to 30 A for each channel and a maximum of 100 A for the entire system.
  • Use 10 AWG (6 mm2) wires for accessories that use 20 to 30 A.
  • Use 12 AWG (4 mm2) wires for accessories that use 10 to 20 A.
  • Use 14 AWG (2.5 mm2) wires for accessories that use less than 10 A.
  • Use the appropriate size terminals for all accessory connections.
  • Crimp all terminal connectors securely.
  1. Connect the positive wire from the accessory | to one of the accessory terminals | on the | device.
    Wiring diagram of power and ground connections with callouts
  2. Connect the negative or ground wire Call-out number three to an unpainted ground stud Call-out number four on the vehicle frame, to a ground distribution block or directly to the negative terminal on the battery.
    NOTICE
    Do not connect the accessory ground wires to the ground terminal (GND) on the | device. Failure to heed this notice could result in personal or property damage or negatively impact device functionality.
  3. Verify that all electrical connections are tight and will not come loose during use.
GUID-B3443908-7800-44A1-BE1E-0D780C075CBA v3
August 2023
