Adding a Routine
  1. From the Garmin PowerSwitch™ app, select Settings > Routines.
  2. If necessary, select Add Routine.
  3. Select When.
  4. Select a trigger:
    • To set a switch to trigger when your vehicle reaches a specific speed, select Speed > Next and follow the on-screen instructions to enter speed thresholds.
    • To set a switch to trigger at a specific time each day, select Time > Next and enter a time.
    • To set a switch to trigger at sunrise, select Sunrise.
    • To set a switch to trigger at sunset, select Sunset.
  5. Select Add Action.
  6. Select a device, a switch, an action and a button mode.
  7. If necessary, use the slider to adjust the dimmer.
  8. Select Save.
GUID-B3443908-7800-44A1-BE1E-0D780C075CBA v3
August 2023
