Straight Line Routes
For areas without defined roads or trails, the device guides you to your destination using a straight line route. You can set multiple waypoints to navigate a route through areas without roads.
Active straight line route on a navigation map with callouts
Call-out number one
Distance to the destination.
Call-out number two
Route highlighted on the map.
Call-out number three
Vehicle speed.
Call-out number four
Map tools. Provides tools to show you more information about your route and surroundings.
Call-out number five
Map layers. Allows you to change the map orientation and add topographic and BirdsEye imagery to your map view.
GUID-B3443908-7800-44A1-BE1E-0D780C075CBA v3
August 2023
