Stereo Controls
Front view of the device with callouts
Dial
  • Turn to adjust the volume.
  • When adjusting the volume, press to switch between zones.
  • Turn to move through the menus or adjust a setting.
  • When in a menu, press to select the highlighted option.
  • Press and hold to activate certain functions such as opening the radio presets or muting all connected stereos from the mute screen (Muting all Connected Stereos).
Source button
Press to change the source.
TIP: You can turn the dial to browse, and press the dial to select the source. You can also swipe the screen up and down, and touch a source on the screen.
Press and hold to open the GROUPS menu when connected to a Fusion PartyBus™ network (Fusion PartyBus Networking).
Menu symbol
Press to open the menu.
Power button
  • Press to turn on the stereo.
  • Press to mute the audio.
  • Press and hold to turn off the stereo or all stereos on the network.
  • Press and hold for longer than 10 seconds to reset the stereo.
GUID-AA746CCF-6D74-481B-AE87-1EA928679A4A v11
January 2025
