Fusion PartyBus Networking
The Fusion PartyBus™ networking feature allows you to connect multiple compatible stereos together on a network, using a combination of wired or wireless connections.
You cannot use Wi‑Fi® networking when a stereo is connected to a Garmin network.
You can group a compatible stereo, such as the Fusion Apollo™ RA770 stereo, with other compatible stereos connected to the Fusion PartyBus network. Grouped stereos can share available sources and control media playback on all of the stereos in the group, which allows for a synchronized audio experience across the vessel. You can quickly create, edit, and break up groups as needed from any compatible stereo or remote control on the network.
You can use compatible stereos and remote controls, whether they are grouped or not, to adjust the volume of the available speaker zones for any stereo on the network.
You should refer to the installation instructions provided with your stereo when constructing the Fusion PartyBus network.
You can connect up to eight Fusion PartyBus stereos on a network wirelessly.
