DAB Playback
When you connect the MS-DAB100A module and antenna to the Fusion Apollo™ RA770 stereo, you can tune in to and play DAB stations. For instructions on connecting the DAB adapter and antenna, see the installation instructions provided with your adapter and antenna.
DAB broadcasts are not available in all regions. When the stereo is not set to a compatible region, the DAB source is not available.
