Scanning for DAB Stations
Before you can scan for DAB stations, you must connect a compatible DAB module and antenna (not included) to the stereo.
NOTE: Because DAB signals are broadcast in select countries only, you must set the tuner region to a location where DAB signals are broadcast.
  1. Select the DAB source.
  2. Hold DAB tuning mode symbol to scan for available DAB stations.
    When scanning is complete, the first available station in the first ensemble found begins playing.
    NOTE: After the first scan is complete, you can hold DAB tuning mode symbol again to re-scan for DAB stations. When the re-scan is complete, the system starts playing the first station in the ensemble you were listening to when you started the re-scan.
GUID-AA746CCF-6D74-481B-AE87-1EA928679A4A v11
January 2025
