Connecting a Compatible Bluetooth Device
You can play media from a compatible Bluetooth® device using the Bluetooth wireless connection.
You can control the music playback with the media app on a Bluetooth device or using the Fusion® Audio remote control app (Fusion Audio Wireless Remote Control App).
  1. Select the BLUETOOTH source.
  2. Select Menu symbol > BLUETOOTH > CONNECTIONS > DISCOVERABLE to make the stereo visible to your compatible Bluetooth device.
  3. Enable Bluetooth on your compatible Bluetooth device.
  4. Bring the compatible Bluetooth device within 10 m (33 ft.) of the stereo.
  5. On your compatible Bluetooth device, search for Bluetooth devices.
  6. On your compatible Bluetooth device, select the stereo from the list of detected devices.
    NOTE: The stereo appears in the Bluetooth device list as the device name (the default name is MS-RA770 unless it was changed in the settings).
  7. On your compatible Bluetooth device, follow the on-screen instructions to pair and connect to the discovered stereo.
    When pairing, your compatible Bluetooth device may ask you to confirm a code on the stereo. If the stereo shows a code, you can compare them before pairing. If the stereo does not display a code, it should connect correctly when you confirm the message on the Bluetooth device.
  8. If your compatible Bluetooth device does not immediately connect to the stereo, repeat steps 1 through 7.
    NOTE: If another Bluetooth device is already playing music on the stereo, connecting a new device will not interrupt playback. You must select the newly-added device if you want to use it instead (Selecting a Different Bluetooth Device).
The DISCOVERABLE setting is disabled automatically after two minutes.
NOTE: On some Bluetooth devices, adjusting the volume on the device affects the volume level on the stereo.
GUID-AA746CCF-6D74-481B-AE87-1EA928679A4A v11
January 2025
