Fusion Audio Wireless Remote Control App
You can use the Fusion® Audio remote control app on your compatible Apple® or Android™ device to adjust the stereo volume, change the source, control playback, select and manage radio presets, and adjust some stereo settings.You can use the app to set up and configure DSP profiles on the stereo.You can use the app to update the stereo software.
The app communicates with the stereo using a wireless connection to the mobile device. You must connect your compatible device to the stereo using Bluetooth® or Wi‑Fi® technology to use the app.
If the stereo is connected to a network with a Wi‑Fi access point, the app can communicate with the stereo using the network for greater range than a Bluetooth connection.
NOTE: You cannot update the stereo software using a Bluetooth connection. You must connect the app using a Wi‑Fi connection to update the stereo software wirelessly.
You can connect an Apple device to the stereo using a USB cable to update the stereo software.
For information about the Fusion Audio remote control app for compatible Apple or Android devices, go to the Apple App Store℠ or the Google Play™ store.
GUID-AA746CCF-6D74-481B-AE87-1EA928679A4A v11
January 2025
