None
Fusion Audio remote control app
USB flash drive (single-stereo update)
USB flash drive (entertainment package network update)
You must use the USB flash drive entertainment package update method to update a connected lighting controller.
Updating using the remote control app updates the stereo only, and does not update a connected lighting controller.
One or more
Fusion Apollo stereos not connected as part of a
Fusion entertainment network
One or more
Garmin Spectra lighting controllers connected to the same
NMEA 2000 network as the stereo or stereos
USB flash drive (entertainment package network update1)
You must use the USB flash drive entertainment package update method to update the lighting controller or controllers.
Because the stereos are not connected as part of a
Fusion entertainment network, you must update each stereo individually, using either the either USB flash drive method or using the remote control app.
Multiple
Fusion Apollo stereos connected as part of a
Fusion entertainment network with a mix of stereos connected using Ethernet cables and
Wi‑Fi connections
With or without one or more
NMEA 2000 network as at least one of the stereos
Only stereos connected as part of a
Fusion entertainment network using an Ethernet cable update at the same time when using the entertainment package network update. Stereos connected using
Wi‑Fi technology must be updated individually.
If you update using the remote control app or USB flash drive single-stereo update, it can update multiple stereos connected as part of a
Fusion entertainment network using Ethernet cables as long as they are all the same model. Stereos of different models must be updated individually. The remote control app or USB flash drive single-stereo update does not update a connected lighting controller.
Multiple
Fusion Apollo stereos connected as part of an entertainment network using Ethernet cables only (no stereos connected using
Wi‑Fi technology)
You must use the USB flash drive entertainment package update method to update the lighting controller or controllers. The entertainment package update method also updates all stereos connected as part of a
Fusion entertainment network using Ethernet cables, regardless of model.
If you update using the remote control app or a USB flash drive single-stereo update, it can update multiple stereos connected as part of a
One or more
Fusion Apollo stereos connected to a
Garmin chartplotter using a wired
Garmin BlueNet™ or Garmin Marine Network connection.
With or without a single or multiple
NMEA 2000 network as at least one of the chartplotters or stereos
The full marine package update method updates all
Garmin devices connected to the wired
Garmin BlueNet or Garmin Marine Network and the
NMEA 2000 network at one time, including connected stereos and lighting controllers.
If you have an
NRX remote control or a DAB module connected to the stereo, it is not updated as part of the full marine package update method. You must perform updates to those devices individually (Update Options ).
If your stereo or stereos are connected to a
Garmin chartplotter, you should perform an update using the full marine package update method on a memory card thorough the chartplotter. It is not recommend to use any other update method with this setup.
If your stereo or stereos are not running SW version 6.20 or later, you should disconnect it from the
Garmin networked devices and perform a single-stereo update. After this update, you can reconnect the stereo and use the full marine package update method for all future updates.
