Wireless Access Point Settings
Select Menu symbol > SETTINGS > NETWORK > ADVANCED > WI-FI ACCESS POINT.
NOTE: You must configure the device to be a wireless access point before you can change the settings (Setting the Fusion PartyBus Device as a Wireless Access Point).
NOTE:
SSID
Sets the SSID, or name, for the network.
AP SECURITY
Sets the type of wireless security protocol used by the access point.
NOTE: It is strongly recommended that you set the AP SECURITY using WPA2 PERSONAL. It is the most widely-used and secure wireless security protocol.
PASSWORD
Sets the password for the access point. This is not available when the AP SECURITY setting is set to NONE.
COUNTRY
Sets the region where the stereo is located. Different regions may use different channels on the wireless spectrum, so you should set this to best accommodate local wireless devices.
CHANNEL
Sets the access point to use a group of channels in the high, low, or middle range of the available spectrum for your region. You may experience better performance if you set the channel in a range with fewer broadcasting access points.
DHCP SERVER
Sets the device to act as a wireless access point and the DHCP server on the network (DHCP Settings).
WPS
Initiates a Wi‑Fi® Protected Setup (WPS) connection. Devices with a WPS button or setting can connect to the access point on this stereo when the WPS connection is active.
NOTE: It can take up to two minutes to successfully connect to the access point after you select WPS.
GUID-AA746CCF-6D74-481B-AE87-1EA928679A4A v11
January 2025
