Methods to Add a Contact to a Handheld Device
Using MURS/VHF
Allows you to add a handheld device contact after you have placed your handheld device into pairing mode.
This method is helpful when you are adding a new device to the system prior to leaving for the hunt (Adding a Contact Using Wireless Pairing).
Entering the device ID
Allows you to add a handheld device contact that is not in the area. This method requires the contact to find and communicate their handheld device code to the person adding the device contact.
This method is helpful when you would like to add a handheld device contact during a hunt, but you are not near the device. For example, if you are adding another member of your hunting party to your handheld device, but you do not own the device (Adding a Contact Using a Contact ID).
Sharing wirelessly using ANT‍+® wireless technology
Allows you to add a handheld device that you do not own as a contact. This method does not require the contact to find and communicate their device code to the person adding the device. The two handheld devices must be within a range of 3 m (10 ft.) to share data wirelessly.
This method is helpful when you want to add a handheld device during a hunt without entering the device ID (Adding a Contact Using Wireless Pairing).
GUID-AA041605-DE53-4A18-B076-5DCB8D4F9007 v4
March 2026
