Adding a Contact Using a Contact ID
Before you can add a hunter using a contact ID, the hunter must find the contact ID (Finding Your Contact ID) and send it to you.
If you are not near the hunter you want to add, you can add the hunter using a contact ID.
  1. On your handheld device, select Dog List > Contacts > Add > Enter ID.
  2. Select the contact ID for the contact you are adding.
  3. Enter the name of the contact, and select Check.
The contact is added to your handheld device.
You can repeat this procedure using another hunter's handheld device to add your contact ID to that device.
GUID-AA041605-DE53-4A18-B076-5DCB8D4F9007 v4
March 2026
