Navigating a Route
  1. On the remote control, select Menu icon > Routes.
    A list of the ten closest routes is shown.
  2. Select a route.
  3. Select Navigate To.
  4. Select an option:
    • To navigate the route from the starting point used when the route was created, select Forward.
    • To navigate the route from the destination point used when the route was created, select Backward.
    • To navigate from your current location to the beginning of the route, then navigate the route, select From Start.
  5. Turn on the propeller (Turning the Propeller On and Off).
    The trolling motor drives along the route in the chosen direction (Navigating).
When you reach the end of the route, the motor turns on Anchor Mode to maintain your position.
NOTE: You can configure how the motor operates when you reach the end of a route (Trolling Motor Settings).
GUID-A7668193-255A-4F7A-AAEC-C153FB825CB4 v3
August 2026
