Profile
Adding a Profile
You can add a .pro file that contains profile information by creating it using the Applied Ballistics Quantum™ app and transferring the file to the AB folder on the device (Transferring Files to Your Device Using a Computer). You can also create a profile using your Garmin® device.
  1. From the Applied Ballistics app, press MENU.
  2. Select Profile.
  3. Select an option:
    • To create a brand new profile, select + Profile
    • To create a new profile based on an existing profile, select the profile, select Copy, and enter a name.
Editing a Profile
  2. Select Profile.
  3. Select a profile.
  4. If necessary, select Rename, and enter a name.
  5. Select Properties.
  6. Select an option:
    NOTE: Some options only appear when you enable the Advanced Settings option.
    • To enter the bullet properties, select Bullet Data, and select an option.
      TIP: You can select Bullet Library to automatically enter bullet properties from the Applied Ballistics® bullet database. If you manually enter the bullet properties, you can find the information on the bullet manufacturer's website.
    • To enter the gun properties, select Gun Data, and select an option.
    • To enter the scope properties, select Scope, and select an option.
    • To calibrate the muzzle velocity to provide a more accurate solution in the supersonic range for your firearm, select Calibrate Muzzle Velocity, select an option, and select Use.
    • To calibrate the custom drag factor, select Calibrate Custom Drag Factor, select an option, and select Use.
    • To edit the muzzle velocity temperature table, select MV Temp Table, press MENU, select Edit, and select a value to edit.
      NOTE: If necessary, you can select Clear MV-Temp to reset the muzzle velocity temperature table back to the default values.
    • To calibrate the drop scale factor to provide a more accurate solution at or beyond the transonic range for your firearm, select Drop Scale Factor > Calibrate DSF, select an option, and select Use.
      NOTE: Garmin recommends you calibrate the muzzle velocity prior to the drop scale factor. After you calibrate the drop scale factor, you can select View DSF Table to view the drop scale factor table. If necessary, you can select Clear DSF Table to reset the drop scale factor table to the default values.
Deleting a Profile
NOTE: You cannot delete your current profile.
  2. Select Profile.
  4. Select Delete.
Selecting a Different Profile
  2. Select Profile.
  4. Select Set as current.
GUID-A494ACED-FFD6-481B-9DAF-D521E717FE5F v6
October 2026
