Voice Commands
The voice command system is designed to detect natural speech. This is a list of commonly used voice commands, but the GPSMAP® H1i Plus navigator does not require these exact phrases. You can try saying variations of these commands in a way that is natural to you.
Voice Help Command
Function
What can I say?
Shows a list of common voice commands.
Device and Screen Functions
Voice Command
Function
Turn off flashlight
Example of a command to disable a device feature. For example, this one turns off the flashlight.
Increase brightness
Raises the screen brightness level.
Automatic brightness
Automatically adjusts the screen brightness based on the ambient light.
Set brightness to 80
Sets the screen brightness level to a specified percent. Available numbers are 0-100%.
Home screen
Open the home page.
Nevermind
Dismisses the current voice command. For example, you may use this command if you misspoke or were interrupted.
Clock Functions
Voice Command
Function
Start stopwatch
Starts the stopwatch.
Stop stopwatch
Stops the stopwatch.
App and Activity Functions
Voice Command
Function
Show me the weather
Example of a command to open an app on the device. For example, this one opens the weather app.
Switch to the compass app
Example of a command to open an app on the device. For example, this one opens the compass.
Start activity
Starts recording an activity with the current activity type.
Switch to hike
Changes the current activity type.
Start tracking
Starts inReach® tracking.
NOTE: The apps and activities listed are examples, but you can control all of the default apps and activities with voice commands (Apps).
Navigation Functions
Voice Command
Function
Begin navigation
Opens the search menu to search for a destination.
Save location
Saves your current location.
Media Functions
Voice Command
Function
Change volume to 8
Adjusts the volume to the specified level. Available numbers are 0-10.
Decrease volume
Lowers the audio volume.
Mute
Silences all audio.
Read my messages
Begins reading unread inReach messages on the device, starting with the oldest.
GUID-A494ACED-FFD6-481B-9DAF-D521E717FE5F v6
October 2026
