Using the Flashlight
WARNING
This device may have a flashlight that can be programmed to flash at various intervals. Consult your physician if you have epilepsy or are sensitive to bright or flashing lights.
You can use the flashlight on your GPSMAP® device.
  1. Select Apps list to open the apps list.
  2. Select Flashlight.
  3. Press ENTER or select Flashlight to turn on the flashlight.
    NOTE: Using the flashlight can reduce battery life. You can use the brightness slider to reduce the brightness and extend the life of the battery.
  4. Press MENU to open the options menu.
  5. Select Strobe to program the flashlight to flash in a strobe pattern.
    NOTE: Using the strobe can reduce battery life. You can select Left arrow or Right arrow to change the strobe pattern to reduce the flash frequency and extend the life of the battery.
    CAUTION
    Programming the flashlight to flash in an SOS pattern will not contact emergency services on your behalf.
GUID-A494ACED-FFD6-481B-9DAF-D521E717FE5F v6
October 2026
