Navigating a Saved Course
  1. From the home page, select Saved.
  2. Select a course.
    TIP: You can select Course to filter your saved data for courses.
  3. Select Navigate.
  4. Select your navigation options:
    • To change the activity type, select the activity name. Activity types include walking, hiking, hunting, and more.
    • To adjust the course to follow map data and recalculate as needed, enable the Routing toggle switch.
    • To set how the device routes from one point to the next, select Advanced Settings (Routing Settings).
  5. Select Go.
    The device calculates your route and displays it on the map. You can navigate using the navigation tools (Map, Compass).
GUID-A494ACED-FFD6-481B-9DAF-D521E717FE5F v6
October 2026
