Updating an inReach Weather Forecast Over Satellite
If you are in a location without active internet access, your GPSMAP® H1i Plus satellite communicator can update an inReach® weather forecast that has expired or contains outdated information. Updating a forecast incurs the same data charges or additional charges as requesting a forecast.
  1. Select Apps list to open the apps list.
  2. Select Weather.
  3. Press MENU to open the options menu.
  4. Select Update Forecast > Update Forecast.
The satellite communicator requests an updated forecast. If you update the My Location forecast, the satellite communicator requests an updated forecast for your current location. It may take several minutes to receive the updated weather forecast data.
GUID-A494ACED-FFD6-481B-9DAF-D521E717FE5F v6
October 2026
