Saving or Navigating to a Location on the Map
You can select any location on the map. You can save the location or start navigating to it.
  1. Pan and zoom the map to position the crosshairs (Viewing the Map).
  2. Select an option:
    • Tap the location or coordinates at the bottom of the screen to select the point indicated by the crosshairs.
    • Hold Upper-right button to select the point indicated by the crosshairs.
  3. If necessary, select a nearby point of interest.
  4. Select an option:
    • To start navigating to the location, select Go.
    • To save the location, select Save Location.
    • To view information about the location, select Review.
GUID-A315BE5B-E191-4238-9712-D9C368997ADB v8
June 2026
