Viewing the Map
  1. Select an option to open the map:
    • Press Upper-right button, and select Map to view the map without starting an activity.
    • Go outside, start a GPS activity (Starting an Activity), and scroll to the map screen.
  2. If necessary, wait while the watch locates satellites.
  3. Select an option to zoom on the map:
    • In the Map app, select Zoom in or Zoom out.
    • In an activity, swipe down to unlock the touchscreen (if necessary), tap the map, and select Zoom in or Zoom out.
    • In an activity, hold Middle-left button, select Map Controls, and select Zoom in or Zoom out.
  4. Select an option to pan the map:
    • Swipe down to unlock the touchscreen (if necessary), tap the map, and tap and drag to position the crosshairs.
    • In the Map app, select Menu > Pan/Zoom, and press Upper-right button to toggle between panning up and down, panning left and right, or zooming. You can press Lower-right button to exit panning mode.
    • In an activity, hold Middle-left button, select Map Controls > Menu > Pan/Zoom, and press Upper-right button to toggle between panning up and down, panning left and right, or zooming. You can press Lower-right button to exit panning mode.
GUID-A315BE5B-E191-4238-9712-D9C368997ADB v8
June 2026
