Broadcasting Heart Rate Data
You can broadcast your heart rate data from your watch and view it on paired devices. Broadcasting heart rate data decreases battery life.
TIP: You can customize the activity settings to broadcast your heart rate data automatically when you begin an activity (Activity Settings). For example, you can broadcast your heart rate data to an Edge® device while cycling.
  1. Select an option:
    • Hold Middle-left button, and select Watch Settings > Health & Wellness > Wrist Heart Rate > Broadcast Heart Rate.
    • Hold Upper-left button to open the controls menu, and select Broadcast heart rate data.
      NOTE: You can add options to the controls menu (Customizing the Controls Menu).
  2. Press Upper-right button.
    The watch starts broadcasting your heart rate data.
  3. Pair your watch with your compatible device.
    NOTE: The pairing instructions differ for each Garmin® compatible device. See your owner's manual.
  4. Press Upper-right button to stop broadcasting your heart rate data.
GUID-A315BE5B-E191-4238-9712-D9C368997ADB v1
September 2024
