Getting Your VO2 Max. Estimate for Running
This feature requires wrist-based heart rate or a compatible chest heart rate monitor. If you are using a chest heart rate monitor, you must put it on and pair it with your watch (Pairing Your Wireless Sensors).
For the most accurate estimate, complete the user profile setup (Setting Up Your User Profile), and set your maximum heart rate (Setting Your Heart Rate Zones). The estimate may seem inaccurate at first. The watch requires a few runs to learn about your running performance. You can disable VO2 max. recording for ultra run and trail run activities if you do not want those run types to affect your VO2 max. estimate (Activity Settings).
  1. Start a running activity.
  2. Run for at least 10 minutes outdoors.
  3. After your run, select Save.
  4. Press Middle-left button or Lower-left button to scroll through the performance measurements.
GUID-A315BE5B-E191-4238-9712-D9C368997ADB v1
September 2024
