Connecting the Fusion PartyBus Device to a Wireless Access Point
You can connect this device to a wireless access point on a router or compatible Fusion PartyBus™ device on the network. This device can connect using Wi‑Fi® Protected Setup (WPS), if it is supported by your access point. This device can connect using Apple® Accessory Configuration (WAC) using a supported Apple device.
  1. Select Menu > SETTINGS > NETWORK > WI-FI CLIENT > SSID.
    A list of wireless access points within range appears.
  2. Select the Fusion PartyBus wireless access point.
  3. If necessary, select PASSWORD, enter the password, and select Check mark.
  4. Select SAVE.
NOTE: After you connect the stereo to a wireless access point, you cannot use the wired network connection.
GUID-93B550BE-32FB-4B88-B776-F28617ABA7D5 v5
July 2026
