Wiring Harness Wire and Connector Identification
Device connectors and cables
Wire or RCA Connector Function
Bare Wire Color or RCA Label Name
Notes
Ground (-)
Black
Connects to the power source (Power Connection).
Power (+)
Yellow
Ignition
Red
Amplifier on
Blue
Connects to optional external amplifiers, enabling them to turn on when the stereo turns on.
NOTICE
A connected amplifier must use the same ground (-) as the stereo for this signal wire to function correctly.
Telemute
Brown
Activates when connected to the same ground (-) as the stereo.
For example, when you connect this wire to a compatible, hands-free mobile kit, the audio mutes or the input switches to Aux1 when a call is received and the kit connects this wire to the same ground (-) as the stereo. You can enable this functionality from the settings menu.
Dim
Orange
Connects to the boat's illumination wire to dim the stereo screen when the lights are on.
The gauge of the illumination wire must be suitable for the fuse supplying the circuit it is connected to.
NOTICE
The stereo and the vessel must use the same ground (-) connection for the Dim wire to function correctly.
Speaker zone 1 left (+)
White
Speaker zone 1 left (-)
White/black
Speaker zone 1 right (+)
Gray
Speaker zone 1 right (-)
Gray/black
Speaker zone 2 left (+)
Green
Speaker zone 2 left (-)
Green/black
Speaker zone 2 right (+)
Purple
Speaker zone 2 right (-)
Purple/black
Zone 1 line out (left)
Zone 1 line out (right)
Zone 1 subwoofer out
ZONE 1
ZONE 1 SUB OUT
Provides output to an external amplifier, and is associated with the volume control for zone 1.
Each subwoofer cable provides a single mono output to a powered subwoofer or subwoofer amplifier.
Zone 2 line out (left)
Zone 2 line out (right)
Zone 2 subwoofer out
ZONE 2
ZONE 2 SUB OUT
Provides output to an external amplifier, and is associated with the volume control for zone 2.
Auxiliary in 1 left
Auxiliary in 1 right
AUX IN 1
Provides an RCA stereo line input for audio sources, such as a CD or MP3 player.
Zone 3 line out (left )
Zone 3 line out (right)
Zone 3 subwoofer out
ZONE 3
ZONE 3 SUB OUT
Provides output to an external amplifier, and is associated with the volume control for zone 3.
Zone 4 line out (left)
Zone 4 line out (right)
Zone 4 subwoofer out
ZONE 4
ZONE 4 SUB OUT
Provides output to an external amplifier, and is associated with the volume control for zone 4.
Auxiliary in 2 left
Auxiliary in 2 right
AUX IN 2
Provides and RCA stereo line input for audio sources, such as a CD or MP3 player.
GUID-93B550BE-32FB-4B88-B776-F28617ABA7D5 v5
July 2026
