Wireless Networking Considerations
When you are planning your network, observe the following considerations for all wireless connections.
  • Wired connections are more reliable than wireless connections. You should plan your network to use network cables, but if it is not possible, many Fusion PartyBus™ devices are Wi‑Fi® compatible. You can connect them to wireless routers or access points.
  • If you install a wireless router on the network, it should be configured to be the DHCP server by default. See your wireless router instructions for more information.
  • If you are not using a wireless router, you can configure this device as a wireless access point, so you can connect other devices within wireless range.
    NOTE: You should not configure this device as a wireless access point if you have a router installed on the network, because it may introduce DHCP conflicts and result in poor network performance.
  • If you connect a Fusion PartyBus device to the network as a WI-FI CLIENT, you cannot connect any additional wired Fusion PartyBus devices to that device.
  • You can connect a smartphone to the wireless network to control any stereo on the network using the Fusion® Audio app.
  • You can connect an Apple® device to the wireless network to stream media to multiple stereos on the network using Apple AirPlay® 2.
  • Connecting a Bluetooth® device to the stereo may interfere with some Wi‑Fi connections.
  • Wi‑Fi signals may interfere with Bluetooth device connections. You should turn off the Wi‑Fi setting on your stereo if you are not using it to connect to a wireless network or to provide a wireless access point.
GUID-93B550BE-32FB-4B88-B776-F28617ABA7D5 v5
July 2026
