Pairing the Varia Vue with a Compatible Edge Bike Computer
You can pair your Varia™ Vue with a compatible Edge® bike computer through an open connection using ANT‍+® technology. After the initial pairing, the Edge bike computer automatically connects to the Varia device when you start your activity and the device is active and within range. When paired, the device controls appear on the compatible bike computer. You can also control the camera on the compatible bike computer.
TIP: To check if your bike computer is compatible, go to www.garmin.com/variavue, and select the Compatible Devices tab.
  1. Bring the Edge bike computer within range (3 m) of the Varia Vue.
    NOTE: Stay 10 m away from other sensors that use ANT‍+ technology while pairing.
  2. Turn on the Edge bike computer.
  3. Select Menu symbol > Sensors > Add Sensor > Search All.
  4. While the Varia Vue headlight is turned off, hold the device button for 2 seconds to enter pairing mode.
    The status LED flashes Purple, and the headlight turns on. The device is in pairing mode for 5 minutes or until you press the device button.
  5. Select your sensor.
When the headlight device is paired with your Edge bike computer, the sensor status is Connected. The Bike light sensor symbol (bike light) status icon appears solid on the top banner of the home screen.
GUID-8DFBD71F-8C87-485C-BDD0-9B8FD2DE86DD v2
May 2025
