Resetting the Device
You can reset the device if it stops responding.
NOTE: Resetting the device deletes the pairing connections from the device, and clears all personal data stored on the device. It does not remove any data stored on the memory card. To protect your data on the memory card, you should format or remove the memory card from the device (Formatting Your Memory Card).
  1. Turn the device on (Turning On and Off the Device).
  2. Hold both buttons for 10 seconds.
    The LED flashes Green Amber Red continuously, until the reset is complete.
GUID-8DFBD71F-8C87-485C-BDD0-9B8FD2DE86DD v2
May 2025
