The status LED flashes red while charging Check the USB cable, connectors, and ports for damage. Make sure the AC adapter or computer USB port is generating power. You can check this several ways. For example, you can check whether other devices powered by the source are functioning. Charge the device within the approved charging temperature range (Specifications). Parent Topic: TroubleshootingHomeTroubleshootingThe status LED flashes red while charging
