Activity Settings
These settings allow you to customize each preloaded activity based on your needs.‍ For example, you can customize data screens and enable alerts and training features.‍ Not all settings are available for all activity types. Some activity types have separate settings lists.
From the watch face, swipe left, select Activities, select an activity, scroll down. and select the activity settings.
Accent Color
Sets the accent color for the activity icon.
Alerts
Sets the training or navigation alerts for the activity (Activity Alerts).
Auto Lap
Sets the options for the Auto Lap® feature to automatically mark laps. The By Distance option marks laps at a specific distance. The By Position option marks laps at a location where you previously pressed Line drawing of the watch with a bottom button callout. The Auto Select option triggers lap alerts on mile or kilometer course points when running a course with timing gates, such as some certified marathons, or at the distance set in the Auto Distance setting. When you complete a lap, a customizable lap alert message appears. This feature is helpful for comparing your performance over different parts of an activity.
Auto Pause
Sets the options for the Auto Pause® feature to stop recording data when you stop moving or when you drop below a specified speed. This feature is helpful if your activity includes stop lights or other places where you must stop.
Auto Rest
Automatically creates a rest interval when you stop moving during a pool swim activity (Swim Auto Rest and Manual Rest).
Auto Scroll
Automatically scrolls through all of the activity data screens while the activity timer is running.
Auto Set
Automatically starts and stops exercise sets during a strength training activity.
Auto Start
Automatically starts the activity timer when you start moving (for example, Motocross).
Broadcast Heart Rate
Automatically broadcasts heart rate data from your watch to paired devices when you start the activity (Broadcasting Heart Rate Data).
Broadcast to GameOn
Automatically broadcasts biometrics data to the Garmin GameOn™ app when you start a gaming activity.
Countdown Start
Enables a countdown timer for pool swimming intervals.
Data Screens
Customizes data screens and adds new data screens for the activity (Customizing the Data Screens).
Edit Weight
Prompts you to add the weight used for an exercise set during a strength training or cardio activity.
Ending Alerts
Sets an alert for two or five minutes before the end of your meditation activity.
Gear Selection
After you complete an activity, prompts you to select the gear or equipment you used during the activity. You can add and delete gear in your Garmin Connect™ account (Garmin Connect).
Jump Mode
Sets the jump rope activity target to a set time, number of reps, or open ended.
Lane Number
Sets your lane number for track running.
Laps
Configures the settings for the Lap Key and Lap Alert options.
Lap Alert
Sets the data fields to show for laps.
Lap Key
Enables the Line drawing of the watch with a bottom button callout button for recording a lap or rest during an activity.
Obstacle Tracking
Saves obstacle locations from your first loop of the course. On repeat loops of the course, the watch uses the saved locations to switch between obstacle and running intervals (Recording an Obstacle Racing Activity).
Pool Size
Sets the pool length for pool swimming.
Power Save Timeout
Sets the timeout limit for the watch to stay in activity mode while waiting for you to start the activity, for example, when you are waiting for a race to start. The Normal option sets the watch to enter low-power watch mode after 5 minutes of inactivity. The Extended option sets the watch to enter low-power watch mode after 25 minutes of inactivity. The extended mode can result in shorter battery life between charges.
Record Temperature
Records the ambient temperature around the watch or from a paired temperature sensor.
Record VO2 Max.
Records a VO2 max. estimate during an activity that is usually not a performance activity, such as Trail Run.
Rename
Sets the activity name.
Rep Counting
Records rep counts during a workout. The Workouts Only option records rep counts during guided workouts only.
Restore Defaults
Resets the activity settings.
Running Power
Records running power data and customizes the settings.
Runs
Satellites
Sets the satellite system to use for the activity (Satellite Settings).
Self Evaluation
Sets how often you evaluate your perceived effort for the activity (Evaluating an Activity).
Stroke Detection
Automatically detects your stroke type for pool swimming.
Touch Lock
Enables swiping down from the top of the screen to unlock the touchscreen.
Track Detection
Automatically detects if you are on a running track.
Units
Sets the units of measure for the activity.
Vibration Alerts
Notifies you to inhale or exhale during a breathwork activity.
GUID-8C2C402F-55AC-431F-9CF2-1442B89CE149 v7
September 2026
