Satellite Settings
You can change the GNSS satellite settings to customize the satellite systems used for each activity. For more information about GNSS satellite systems, go to garmin.com/aboutGPS.
From the watch face, press Line drawing of the watch with a top button callout, select Activities, select an activity, scroll down and select the activity settings, and select Satellites.
NOTE: This feature is not available for all activities.
Off
Disables GNSS satellite systems for the activity.
Use Default
Enables the watch to use the default activity focus mode setting for GNSS satellites (Customizing a Default Focus Mode).
GPS Only
Enables the GPS satellite system.
All Systems
Enables multiple GNSS satellite systems. Using multiple GNSS satellite systems together offers increased performance in challenging environments and faster position acquisition than using GPS only. However, using multiple GNSS systems can reduce battery life more quickly than using GPS only.
GUID-8C2C402F-55AC-431F-9CF2-1442B89CE149 v7
September 2026
