Pairing the Radar Device with a Compatible Edge Device
This task is for the Edge® 1000, 830, 530, and 130 devices. If your device is not listed, go to buy.garmin.com.
  1. Bring the Edge device within range (3 m) of the sensor.
    NOTE: Stay 10 m away from other ANT‍+® sensors while pairing.
  2. Turn on the Edge device.
  3. From the Sensors menu, select Add Sensor > Search All.
  4. While the Varia™ RVR315 device is turned off, hold the device key for 1 second to enter active mode.
    The status LED flashes blue, and the radar device turns on.
  5. Select your sensor.
When the sensor is paired with your Edge device, the radar status icon appears solid.
Copyright © Garmin. All rights reserved.GUID-8A0398B5-1411-401F-9A3B-6F9B956A122A v1
