Replacing the Motor
- Remove the antenna (Removing the Antenna).
- Disconnect the motor power cable from the electronics box.
- Using a #2 Phillips screwdriver, remove the screw securing the motor ground wire to one of the motor mounting bosses.
- Using a #2 Phillips screwdriver, remove the other three screws securing the motor to the bottom case.
- Lift the motor out of the bottom cover.
- Make sure the new motor is fully seated in the rubber pad on the bottom of the motor.
- Place the new motor in the mounting location.
- Reinstall the first motor mounting screw holding the ground wire on top of the motor mounting bracket.
- Reinstall the remaining three motor mounting screws.
Connect the new motor power
cable to the electronics box.
TIP: You should use a flat screwdriver to push the motor power cable connector and make sure it is fully seated.
- Reinstall the antenna (Reinstalling the Antenna).
Parent Topic: Service Procedures
