Adding Alternate Time Zones
You can display the current time of day in additional time zones.
NOTE: You can view your alternate time zones in the glance loop (Customizing the Glance Loop).
  1. Hold MENU.
  2. Select Clocks > ALT. TIME ZONES > Add Alt. Time Zone.
  3. Select an option:
    • Select Use Airport Ident. to search for a time zone by entering the alphanumeric identifier for an aviation waypoint.
    • Select Use Map to choose a time zone for a geographic location.
  4. Press UP or DOWN to highlight a region, and press START to select it.
  5. Select a time zone.
  6. If necessary, rename the zone.
GUID-85E8D94D-E009-4EDD-A980-C9EE59C1F323 v13
August 2025
