Altimeter Settings
Hold MENU, and select Sensors & Accessories > Altimeter.
Barometer
Allows you to set the barometric pressure manually, or select a value from the nearest METAR station through the Garmin Connect™ app. Setting the current barometric pressure manually can help to improve the accuracy of the pressure altitude reading.
Altitude Alert
Sets an alarm to vibrate when you reach a specified altitude. The altitude alert is not available in watch mode.
Sync to Elevation
Allows you to synchronize the watch to your current elevation manually.
Set Standard Baro
Allows you to set the standard barometric pressure.
GUID-85E8D94D-E009-4EDD-A980-C9EE59C1F323 v13
August 2025
