Installing the Servo Landing Pad
Install the servo landing pad
, and ensure the cables fit flat in the groove under the servo landing pad and are not twisted or compressed.
TIP: The molded collars on the cables should be in front of the servo landing pad when installed.NOTICEPinching the cables may result in damage to the cables.
Secure the servo landing pad to the mount base using the screws
you removed earlier.
Parent Topic: Assembly Procedures
