Connecting the Cables in the Shaft Cap
- Add dielectric grease to the connectors of the power, GPS data, motor data cables, and transducer cable (if present).
Place the protective coverings on the power cables
Reconnect the power cables and, using a 2.5 mm hex bit or wrench, tighten the set screws
- Slide the protective coverings over the power cable connections.
Secure the power cables to the shaft cap using zip ties at the locations you removed them when disconnecting the power wires
Reconnect the GPS data
and transducer
cable, and tighten the collars.
Align both sections of the motor data cable connector
and press together to connect them.
Parent Topic: Assembly Procedures
