Removing the Release Latch With the motor in the stowed position, use a 4 mm hex bit or wrench to remove the two hex head screws from the latch spring cover . NOTE: The latch spring cover is under spring tension. Take care that you do not lose the cover and springs during disassembly. Slide the release latch out of the steering servo housing. Parent Topic: Disassembly ProceduresHomeDisassembly ProceduresRemoving the Release Latch
