Installing the Cradle Hardware
Apply marine grease to the cradle bushings
Using a 4 mm hex bit or wrench, install the screws
, bushings, cradle catch
, and cradle hook
With the hook on the spring facing toward the mount, insert the cradle tension spring
into the cradle catch and attach the loop on the cradle tension spring on the hook inside the cradle catch
Secure the hook on the cradle tension spring to the notch on the cradle hook
- Repeat this procedure on the opposite side.
- Test the cradle function.
Parent Topic: Assembly Procedures
