Fastening the Swivel Mount without the Cables Running through the Mount
You should complete this procedure only if you are not running the power and transducer cables under the mounting surface and through the swivel-mount base.
  1. Place the base Callout number one on the mounting surface, and fasten it using the appropriate screws or bolts Callout number two.
    Swivel base installation with callouts
  2. Place the swivel mount on the base, and replace the 10 mm M6×1 Phillips screw.
  3. Seal the cable pass-through holes with marine sealant.
Copyright © Garmin. All rights reserved.GUID-760FBC47-2446-4474-B03E-DC2085C730B6 v2
